R
RKB
I write soley instrumental music, a lot of it having some kind of orchestrations. As I don't have access to a 20-piece orchestra, I have to use sampled strings. Unfortunately, making them sound good after they've been recorded is no easy feat. For greater mixing flexibility, I sometimes record each section on its own track. (ie, violins on track 1, violas on track 2, cellos on track 3, basses on track 4). This makes editing on the sequencer while I'm composing a lot easier as well, rather than using a single orchestra patch, and allows me to tweak the performance during the mixdown. But obviously sampled strings don't sound like real strings, and tracking in this manner introduces another level of complexity into the mixing process.
I have two issues that I'd love to hear some suggestions on:
EQ ranges for each instrument: While I can find a multitude of information on the preferred frequencies for kick drum or bass guitar, there's not much out there for orchestral instruments. If anyone has found some key frequencies for each of these stringed instruments, I'd appreciate it. In particular, I'm having trouble keeping the mush out of the basses without sacrificing low-end power. It's either too much, or it's mushy.
Blending: Any suggestions for blending via efx or other means would be greatly appreciated. I generally use a Hall reverb with a very low diffusion rate and about a 2-3 sec delay, 10ms pre-delay. I've also found that cutting the highs at about 7Khz helps to give them more of a full sound. Any other suggestions??
