R
RAMI
Guest
Glen, I sent you a little note thanking you for your post. I understand compression enough that a little math error wouldn't ruin how good a post it was.
apl said:Actually, the compressor ratio works on linear absolute units and the dB scale is logarithmic based on a ratio to reference value.
The article I linked to has a Part 2 (link at the end of part 1) that shows the transfer functions that might illustrate it.
There are also some links to articles on EQ at the top of the page.
In an ideal world it would be "Record - Do Nothing - Do Nothing - Do Nothing"kylen said:This is exactly why I said earlier that Glen gave us 3 years worth of free advice - it's so subtle and easy to miss. EQ both before and after compression - but before only if you are 'fixing' something. The only 2 repairs I like to do right now before compression (always learning so this can change) are hum notching and gently adjusting the slope of the audio (wide bandwidths). In other words if the general slope is a little bass heavy (2db/octave) or treble heavy (5db/octave) I'll throw a shelf or 2 on there to get the slope I like before the compressor. Then put the 'sweetening' EQ on post compressor (as Glen calls it). Fix - Compress - Sweeten (just like a good cup of coffee)![]()
For some of you guys with great recording skills there won't be a need for 'Fix'. I rebalance old tapes so by definition I'm always fixing...
That's OK, I have a hard time typing without typos, so we're evend(-_-)b-Phones said:please keep posting help.. all of you have helped so much.. and btw im american.. and i have a hard time typing my mind without dots...
