B
borsat
i have a mackie ony1620 w/ firewire soudcard option. I record some stuff with this...then i mix and try to master it! all normal, right?
last day a friend of mine send me some stuff recorded by him with a soundcard m-audio audiophile, and the final result was so much higher on volume than mine?
i was thinkink in what could it be, cause i mix all the tracks, then i use a final compression with c4 waves and it's more low... u can fell all the instrument but the general is lower than my friend's stuff..
what's the point? i was thinking...am i using to much compression on each tracks of the mix? this could take some "power" from the instruments?
should i compress less each instrument and than try to compress on the final?
any suggestions
any suggestions
