L
lunatic
Member
Selling some gear that just doesn't get used anymore. Make me a reasonable offer. Buyer pays shipping.
Behringer Composer Pro MDX2200: I have two of these.
(taken from the Behringer website)
• 2-Channel Compressor/Limiter
• Expander/Gate
• Peak Limiter
• Detailed info here http://www.behringer.com/02_products/prodindex.cfm?id=MDX2200&lang=eng
Behringer Powerplay Pro HA4400:
• Professional, universal headphone amplification system for studio and stage
• 4 independent stereo high-power amplifiers in one rack unit
• Maximum audio quality even at high volume levels
• 4 independent input/mix sections for 4 stereo mixes
• Stereo AUX IN per channel for additional signal source
• OUTPUT LEVEL control per channel
• MONO and LEFT/RIGHT MUTE buttons per channel for additional flexibility
• 3 headphone outputs per channel on front and rear panels
• Precise 4-segment LED output level display per channel
• DIRECT IN on the front panel for additional stereo signal source
• Servo-balanced, gold-plated XLR and 1/4" TRS connectors
• Extremely low-noise 4580 operational amplifiers for exceptional sound
• Manufactured under ISO9000 certified management system
• Detailed info here http://www.behringer.com/02_products/prodindex.cfm?id=HA4400&lang=eng
M-Audio DMP2 Microphone Preamp and Direct Box: I have two of these mounted in a rack tray.
(taken from M-Audio)
• 2 independent XLR, fully balanced inputs.
• 2 alternate, independent 1/4” unbalanced, high impedance inputs. These alternate 1/4” inputs are impedance matched for ideal performance with typical electric guitars.
• Separate low cut filters for each channel with switch & LED indicator.
• Separate gain controls for each of the two preamplifiers.
• Individual signal and clipping LEDs for each of the preamplifiers.
• XLR phantom power can be switched on and off for both of the mic preamps.
• Phantom power on or off LED indicator.
• Dual purpose independent 1/4” outputs which accept either tip-ring-sleeve plugs for balanced outs or tip-sleeve plug for unbalanced outs.
• Full 48 Volt phantom power.
• Phase inversion switch.
• Half rack size.
Peace,
Lunatic
• Expander/Gate
• Peak Limiter
• Half rack size.
Peace,
Lunatic
