D
donkeystyle
patlang12 said:I really don't like the way the bass drum sounds in the overheads. Any suggestions on how to record with no bass drum in the overeheads?
the only way to keep it out of the overheads is to not play the bassdrum.
you could do something really drastic like rolling off everything below like 800hz, and scooping alittle bit of around 3k. you'll be left with only a little bit of drums in the overheads, but the sound of the cymbals will be effected and you'll still have to mix the overheads kind of low.........but if you do that, there really was no reason to use the recorderman o.h. technique. And it might cause more problems that you solve. but it's worth trying i guess.
