WERNER 1
Member
Hey guys, let me start off by saying that I'm not a drummer ( I'm the dreaded "Guitarist"!
), but in the process of setting up my home studio I ended up with a set of drums (CB Max SP series) Through the help of you guys here, I ended up re-heading the kit with Evans G2 coated heads and an EQ 4 on the kick.
Basically I used a 4 mic set up, two over heads (SP B1's) set up in one of the ways that was described here - One directly over the snare (4 ft.), and then the other over the right shoulder of the drummer (in this case it was me
------> Sorry! ) pointing directly at the snare - 4 ft from the snare and 4 ft from the other overhead mic.
I had an SM 57 on the snare, and a Beta 58 on the kick just out side of the sound hole.
Anyway, it's a very short clip of me just whacking around. I ended up doing some EQ'ing and adding just a bit of verb as well.
Signal chain ---> Mic(s) ---> DMP-3's----> B1's through 2 DBX 163x comp. ----> Delta 1010 -----> AA 1.5
From what I can tell everything sounds ok to me, but when I listen to it in my car stereo the snare sounds a bit too crispy or even maybe harsh.......but it sounds great on my monitors
(Wharfedale 8.2a's)
Any thoughts or suggestions would be greatly appreciated....
My goal is to decided whether to use loops such as Fairview and BetaMonkey, or to just bite the bullet and try and get the best I can with my "Live" kit.
Thanks, and here's the clip: http://www.soundclick.com/bands/songInfo.cfm?bandID=410286&songID=4615569
Rick
), but in the process of setting up my home studio I ended up with a set of drums (CB Max SP series) Through the help of you guys here, I ended up re-heading the kit with Evans G2 coated heads and an EQ 4 on the kick.Basically I used a 4 mic set up, two over heads (SP B1's) set up in one of the ways that was described here - One directly over the snare (4 ft.), and then the other over the right shoulder of the drummer (in this case it was me
------> Sorry! ) pointing directly at the snare - 4 ft from the snare and 4 ft from the other overhead mic. I had an SM 57 on the snare, and a Beta 58 on the kick just out side of the sound hole.
(Wharfedale 8.2a's)Any thoughts or suggestions would be greatly appreciated....
Rick
) -- but that's causing more headaches than anything else at the moment..
