Put your drum loops or drum hits through a loudness maximizer in peak and fix the desired gain from 6.0 to 12.0.After this ,if your using a loop that is,take it over to recycle and cut before reconstructing in cubse.Once in cubase compress E.G Attack 50ms,Release 0.25s,Ratio 5-10:1and Gain reduction about 5 to 15db and dont forget to drive the signal as hot as u can,without going into the red that is before you go through the compressor.Also,set compressor to hard,stand back,set volume to loud and watch your bird piss her pants.After this go check your penis in the bathroom.Im sure iv put on an inch.
