C
		C. Anthony
I've often run into the problem of one of my disks developing a freeze-up or severe studdering during playback. I'm assuming that dust somehow has gotten into the disk housing. The song will just lock up for a time on a part and will only continue sporatically if at all.
I've "fixed" it more than once by getting the sliding panel on the disk to open and blowing the debris of the recorded disk surface using a can of Blow-off. I've also used a CD wipe to collect some of the crud. This has worked for me sometimes. Has ANYBODY but me had this problem with their disks? I've contacted Sony and other sources for answers about this and never received a reply from anyone. I use my disks professionally and it's embarrasing when this happens. Any input would be welcome.
I'd like to know which side of the disk is read by the laser or are both? (That Blow-off stuff is expensive and I've been cleaning both sides!)
Thanks
P.S. I'm only able to open the sliding panel on the disks by inserting them into an old Sony MD-101 (I use a MDS-40 on the job) that leaves them open somtimes when rejecting. Is there another way to open this panel?
Thanks
