StAbZ
if he has a good horn, strength and confidence. he may not be able to play or improvise the same speed, but that's not what the issue is about...
StAbZ said:if he has a good horn, strength and confidence. he may not be able to play or improvise the same speed, but that's not what the issue is about...
StAbZ said:ur wrong, nickel bells are brighter than brass, gold brass bells are brighter than copper brass.... instruments sound different. also, if you played on a D trumpet instead of Bb the higher notes would sound a lot nicer. ofcourse instrument makes a difference, just because how easy it is to play doesn't change doesn't mean the sound doesn't also change. you can't hear what's coming out from a foot infront of you properly.
in ska music, it's not so much the technique the player has, it's the confidence, strength and how well the particular instrument projects that
bennychico11 said:that in mind, a great player can make a crappy horn sound good too. charlie parker gave a jaw-dropping performance with Joe Timer's orchestra in 1953 where he played on a plastic saxophone.
fraserhutch said:Exactly, my point. There are subtle differences, subtle to the point that the average listener would be hard pressed to tell the difference. Pros can tell the difference.
That isn't to say that a crap horn won't be more difficult to play.
Nah. I bet you not as much as you appear to think.StAbZ said:i have played on many bass trombones in my time playing in bands and orchestras and i can easily notice the difference in tone they give. for example, a besson sovereign bass trombone will give a much harsher sound than say... a holton, even if i use the same playing technique.
i bet if you use a nickel bach stradivarius trumpet and then use a copper brass jupiter trumpet you'll notice the difference, believe me, different instruments react differently
darnold said:Sorry, just wanted to add this. I do think the horns matter quite a bit on sound. There is definately a difference between different horns. But i know its not the major difference in timbre and tone. Ive even used my orchestral horn for some ska stuff that ive done.
Its kind of the same philosophy with microphones. Each microphone has a different color to it, and their could be 3 different microphones that work with a voice. The voice is really what is making the sound, but for certain situations you might use a bright microphone instead of the warm one on the voice. It just depends on what you need to come out in the mix.
Same thing really with trombones. The main voice, tone, timbre of the sound really comes from the player, but the horn is going to project the colors in a little bit different fashion.
Anyway im off to bed.
danny
I still contend this from personal experience, but whatever...StAbZ said:some back-up at last!
Ah, no thread is dead that's got your little green dot in it, my friendWell, you just revived a thread that was dead for 2 whole hours....so there.![]()
If you noticed there hasnt been much brass discussion over the past 3 years....
NYB, I feel your pain; I feel that there isn't a song recorded that can't be improved by the addition of a nice horn section (or at least a cowbellIf you noticed there hasnt been much brass discussion over the past 3 years....
