Signal Levels and Snakes
  • Thread starter Thread starter Phyl
P
Phyl
Guest
I need to build some cables to connect the inputs/outputs of my DAW (MOTU 192) to the line inputs/outputs of my mixer channels. I need to run 10 lines.
Since the MOTU I/O lines are rated at 4dBu, I'm wondering if using snake cable is appropriate. Will bleed between channels be an issue? Would individual cables be a better idea?
You will be fine, no bleed. People even mix signal levels in snakes a lot, sending mic and line signals at the same time. :)
Like Easychair said, you will be fine. Don't worry about it.
