Thaddeus
Hi,
My signal chain is constructed as follows:
Microphones to Yamaha mixing board that has 48V and pre-amps
Thence through dbx compressor/gate
Thence through BBE sound enhancer (usually by-passed)
Thence through Graphic EQ
Thence into DAW (Sonar X3) via a Steinberg USB interface..
At each stage of the chain (except the BBE) I have the opportunity to boost or cut gain.
Here's the question:
Which provides the best signal to noise ratio at the DAW? Starting with the biggest, strongest signal right where the mics attach to the board, paring it down as needed at each stage to avoid clipping/distortion?
Starting with a medium signal and cutting or boosting it at each stage as needed to avoid clipping/distortion?
Or starting with a medium to low signal and boosting at each stage (nearly certain this could not be more wrong, but I put it out there).
thanks in advance!
Thaddeus
thanks in advance!
Thaddeus
