jeff0633 said:
Why can't they call the damn things A, B, bus, and so on?
Jeff
OK, back home now.
First off, you can name the busses anything you want. Therefore, it you prefer A, B, bus, then go ahead and name them that way.
Next, a Bus can either be Send (Aux Bus in Sonar 2 terminology) or a Main or a Subgroup. There is not much difference between a Main and a Subgroup, so let's start there.
A Main is essentially where all of your tracks are going to summed together. If you had a 10 track mix, and everything was routed to one Main, what comes out of the main is essentially your stereo mixdown. In the template you are using, it has been named Master - and that's a pretty good name for it. It's where everything comes together.
However, you might want to create a submix from your drums. Let's say you have 4 drum tracks (snare, kick, and 2 overheads). Instead of routing each track directly to your Master bus, you instead create a new bus called "drums" and you route your 4 drum tracks to this new bus. Then you route the
output of the drums bus to Master. So everything is still going to Master, but the drums are first going through a subgroup Bus. This give you the advantage of having a single fader to control the entire drum kit (rather than 4 faders). It also allows you to patch a single effect that will work on a 4 drums (rather than having to patch the same effect 4 times).
Now, let's talk about the Send (Aux Bus). Unlike the other busses discussed, the send is like a tap off the side of the track. The main signal goes directly through the track and is sent to the Master (or subgroup). However, the Send diverts "some" of the signal to another Bus. It is primarily used for FX like reverb or delay.
A Bus can serve as either a Send or a Master/Subgroup - but not both. You assign it as a Send by going to the FX tab and in the large area to the left of the FX bin, right click and choose insert Send (if it doesn't already appear there). Then choose the Bus you want to use as the Send. Once you do that, you will notice that you no longer see that Bus as a choice among the Track output selections.
This post got much longer than I was expecting - and I'm not sure I'm making anything clearer. So I'm gonna stop now. However, if you have any specific questions, c'mon back and try 'em on us.
