Hmmmmm...
Kingbuzzo,
I did some research on the AXS-1 at the Shure website. There
is no such product according to the company's listings. Are you
sure (no pun intended) about the mic's manufacture? Also if
you purchased it new, it should have some information with it
or at least a description on the body of the mic, like a tag,
plate or something stating what it is- condenser or otherwise,
and its pattern- figure-eight, omnidirectional, cardioid, etc.
If it is a wireless mic, its information may be on the reciever
unit too.
If it looks like a vocal mic, give it a try. Test it first through a
PA system before you try it on your computer, the results
will tell you how well it'll work as a vocal mic, where your
critical distance is, its sensitivity,etc.
Here's hoping it works for you. Depending on the brand and what you paid. Unless you're into a high-end large diaphragm mic, like
a Neumann U-87 or
a Shure KSM-44, a mic is not a high-ticket
purchase, but one definitely deserving the consideration of being
thoroughly researched as if it were.
Good luck and happy hunting,
the Faithmonster
