Slackmaster2K
Gone
It should also be noted that partitioning your drive will NOT improve performance. In fact it will slightly (maybe not noticably) degrade performance because the OS must now access two or more allocation tables on the same disk.
It might make it easier to defrag portions of the drive (which might not be recommended if you're recording interleved audio files!!!) and can provide some "security", but that's about it.
You have to realize that the same physical disk is being accessed, and there's only one data cable on the thing. This whole topic is similar to that of master/slave drive settings. Seperate drives on seperate ports is the only way you'll see no (or little) degradation in file access and transfer times.
Also note that data security might not be a big benefit if you starting to have PHYSICAL disk problems. It is still possible to lose all partitions on a drive simultaneously.
Reinstalling Windows, which I would recommend you do every 6 months to a year, will be easier however, but you'll still have to reinstall your software (though the installation process will be faster since the files are already copied to another partition). However, you could always just delete the windows folder and the hidden files in your root and reinstall. If you do partition, Windows95/98 should require AT MOST 1GB to run properly and maintain a swapfile...that includes installation of a whole buttload of software (which will of course write to \windows, \windows\system and \windows\system32).
So it pretty much boils down, as Emeric said, to organization. It's so tempting to take that huge disk and break it up. I think that this is a result of the speed at which hard drives got larger. 18GB? Shit, last year a 4GB drive was big...and expensive!
Muliple partitions are necessary for running multiple operating systems. They can also ease organization...especially when it comes to data security when running a secure file system NTFS. Not something that you're doing obviously.
Remember, once you partition, you're stuck with it unless you want to spend MORE time working ON your computer than WITH it. You might want to check out Partition Magic which can supposedly repartition drives while maintaining data and operating systems.
Regardless of what you do, make sure you format the drive with FAT32. It won't be visible from NT but that's probably not something you're concerned with. And back up your audio files to another medium! I wish I could
You might also want to look into Windows2000 and see what its specs are in regards to file handling. If 2000 is as stable and friendly as they claim, then you'll probably upgrade eventually and don't want to have to reformat and repartition everything!
(BTW, I'm also curious as to how the Athalon works out. My K6-2 was an extremely noticable piece of crap compared to my Celeron at the same internal clock rate)
Bored at work,
Slackmaster 2000
Bored at work,
Slackmaster 2000
