Druw said:
Hi all,
I made a list of pedals I'm interested in, are they any good?
Electro-Harmonix Big Muff Pi (Russian made)
Danelectro DTB-1 Free Speech Talk Box
Boss CHORUS ENSEMBLE (CE-5 or CE-2 or CE-1)
Boss COMPRESSOR SUSTAINER
Boss GE-7 7 BAND GRAPHIC
Boss LS-2 LINE SELECTOR
Ibanez Tube Screamer ts-9
Is the CE-1 any good?
Thanks
Chorus Ensemble is vintage chorus as used by the likes of Andy Summers, guitarist for the police. Finding one in good order won't be cheap my friend! I think a super chorus (CH-1) or Chorus Ensemble 5 (CE-5), would be fine to get started with. I use a compression/sustainer for blues and some slide work...compression is somewhat of a black art however and its tough to get something you're happy with. Love it for recording though. Same with the graphic EQ, especially if you play alot of lead in band; it cuts through the mix real nice and I also run this through my sound card to record.
The Big Muff distortion...well, I've heard alot of EH pedals are prone to damage after only a little wear and tear...I guess it depends, but it something to think about.
A boss DS 1 will give you some nice distortion, but it might be worth checking out the other distortion units they sell; DS 2 Turbo Distortion, Mega Distortion (more contemporary metal sounds) or a compromise between Overdrive and Distortion, the OS 2.
As for a line selector....why exactly? Do you use two amps? Or what? I mean its ideal for splitting your signal through two different rigs....lets say you run your guitar through a line selector; you take one output through a DS 1 and Crybaby wah and feed it through a Marshall (thats your dirty sound). You take another line out from the pedal into a CE 5, DD3 and put it through a Fender Princeton. This is a very basic example, but i guess its what most people use a line selector for, that and silent tuning. So unless you use two amps...I'm not sure why you'd want it. While we're on the subject of two amps, one of the thing i love about my boss pedals is the 2 ouputs many encorporate. For example, The CH 1 has a mono ouput (pure chorus through one amp) or a stereo output (processed through one amp, unprocessed through another.) This is also present in
the DD3; Your delayed signal comes from one amp, your direct signal from another. You can really get some beautifully full sounds from this.
The BF 3 Flanger (also boss; yes, i may be an addict) lets you split the signal, which gives a nice rotary speaker sound.
The Danelectro pedals are cheap but I've heard great things about the talk box! Looks awesome too, has an actual tube and has gotten some great write-ups. You should check whether it requires its own speaker though...but im pretty sure it doesn't. The TS 9 would be my pick of the lot....a re-issue sea green, not the cheaper grey edition. It's like a blues driver but has more gain and a better low end. I think you should go with this; its collectible and you'll never have a problem selling it if you have to. Its just
a vintage overdrive doing what it should.
Okay so thats almost it, but like the other guy said, go and try before you buy! You might hate some of those pedals, and theres nothing worse than buying one distortion only to replace it with another two weeks down the line. Heres a link to some boss sound samples just to give you an idea.
http://www.bossguitarpedals.com/
Have fun man.
