Share your Korg PXR4 recorded tracks?
  • Thread starter Thread starter slapops
slapops
For those who have recorded with a Korg PXR4
Hi everyone, this is my first post. This seems like a great forum!
Anyways, I am considering getting a Korg PXR4, but I am concerned with the quality. Does anybody have any tracks they would like the share that they recorded with the PXR4?
Thanks alot :)
Yo slapops! I can't post up my best work with the Pandora because it's a cover. I don't want to get into the royalty thing. Send me a PM and a secure address, and I'll mail you a copy on CD. I'm also a pretty good source for Pandora tech. I've been using the little bugger as a notepad and miniaturized remote setup for 3 years.-Richie
Don't worry man everyone posts covers. As long as your not making money out of it your alright.
Yeah man, you should post some of your stuff here, i'm sure everyone would love to hear it!
Had a Pandora until last November. Excellent machine.
Got 2 of my songs uploaded for ya.. I think you need iTunes to listen to them since I ripped them from my CD.
They arent excellent since I'm just an hobby musicians/AE. Both of the songs are recorded with Audio-Technica dynamic mic. Used basic reverb from the Pandora. I'm a fan of high frequences btw.. :p
Yea.. one the songs is in my native language.. so dont bother trying to understand it ;)
http://www.taaviaudio.com/pandora
I hope it helps you a bit.
Feel free to PM with any questions.
Wow
Those sound pretty good! What did you use for the drum track on "I'm standing still"?
Thanks
Thanks!
Yea, the drums are live. Overdubbing.
Nothing can beat real instruments!
So did you plug your Audio-Technica mic directly into the PXR4 without any preamp?
Unfortunately i don't have the luxury of having live drums, can you recommend some kind of drum loop program or something that i can export to the PXR4?
Thanks!
You can plug dynamic mics directly to the pandora. condencer mic would need a preamp or phantom power supply.
You have to get a mic cable that has 1/4" in one end though. Cause tha's was goes into the recorder.
The pxr actually has a small drum machine built in. I dont think you can mix it down in the pandora (not 100% sure about that though). But there's a way around... you record all your tracks with the drum track. and then mix it down through the headphone out onto a computer for example. Worked for me with couple of songs.
yeah, i was just wondering if you had any kind of mixer or equalization before sending to the PXR4, because your voice sounds great
i did some research, are apparantly there isn't a direct way to mix down with the drum loops. What would you use on the computer to edit the drum loop and the song together with your headphone out trick?
Also, are there any layed back drum loops similar to your live drums from "I'm standing still"?
Thanks for the help
The drum loops are panned to center, but don't take up any tracks. There's a level control so you can adjust the relative levels. The easiest way is to export the tracks analog in real time to a sound card or a bigger SIAB. I did some rather good work changing drum algorythms on the fly, and it came out rather well. Seriously- give me an address and I'll send you the CD. If you're concerned about security, send me a work address. BTW- one of the coolest mics to use with the Pandora is SONY ECM-MS957. It's a battery powered mid-side stereo mic which also has a lot of uses in the studio. They are $250 brand new, but I got mine for $150 on ebay. A lot of other stereo mics (AT Pro 24 for example) sound good, but don't produce a hot enough signal to plug directly into the Pandora's stereo line in. The 957 *does not* have that problem. It produces stunning sound with the Pandora.-Richie
Thanks for the help
Nothing between the mic and pandora for sure. I might have applied some eq that is built in the recorder... dont remember exactly, recorded it long time ago.
O yea.. the built in mic is excellent as well... I had big doubts about it but damn.. that little whole in the machine picks up such nice sound.
You can use Audacity ( http://audacity.sourceforge.net/ ) for recording on computer..
And you can mix down with the pandora's drum tracks with a simple 1/8" - 1/8" cable. One end to the headphone out of the PXR and other end to your computer's mic in. Then click "record" in Audacity and "play" in pandora... and the song WITH the drum track will be mixed together.. and you can export it as MP3 in your computer.
I dont remember exactly what kinda beats it had.. but there was a bunch of them. and you can change the speed and volume of them pretty easily.
Actually, I believe you will get better sound by using the line out than the headphone jack. Just remember that it is a -10 line out (as is the stereo line in). I often use the Digi002 with the Pandora because I can set the inputs on the 002 for -10, which decreases the noise floor a lot over sending it into a +4 input. In the remote setting, I usually just use the Pandora and the Sony mic. In the studio, I've jacked about $10,000 worth of outboard gear into the little bugger. My God, it's like a Porsche powered Yugo!
Other uses I've found for the Pandora- It's a kickass metronome, much more pleasant to listen to than the click tracks in Pro Tools or my Roland VS1824CD. It's a pretty good talkback preamp. Just jack a dynamic into it, arm a track, pan to center, and send the stereo line out to the aux in on your headphone amp. One night I was recording a rather good Reggae band, and the reverb in their PA went belly up. I patched up the Pandora with an ebtech line level shifter as an aux loop, and used the Pandora as an FX unit for the PA. The lead vocalist bought one the next day!
The Pandora has often been overlooked because of its size. No one took it very seriously, so I expect it will be discontinued soon. Too bad. Not only is it possibly the best removeable media 4-tracker on the market, but it is simply the smallest recorder that doesn't suck. After 3 1/2 years using it, along with about $30,000 worth of gear, I still use it, and I still find new uses for it.-Richie
Yup, Richie is right, I had forgot about the line out.
"Porsche powered Yugo" haha.. I totally can see that in my mind. I'm from Eastern Europe myself and seen those little guys.
And the pandora is a little beast!
Hmmm, i wonder if it would be easier if i used some kind of drum loop program where i can edit my own drum tracks and to use with the song through Audacity. Any suggestions? The stuff i am recording is all acoustic stuff, so i want a nice layed back beat. But i'm concerned that the pre-canned beats in the PXR4 aren't going to be as dynamic as i want. Any suggestions?
For a mic, i already have a Shure SM58, and i've heard that it produces a good sound when used with the PXR4.
Thanks alot guys!
SM 58 is excellent.
If you are doing mostly acoustic stuff, give a shot on live percussion! Ive used rubbish bins and pens and crystal vases as my instruments many times. Its all about finding the sound you like, not an instrument that looks cool.. and that looks like a real instrument :)
I would say go with live stuff and start experimenting with percussion. No programmed drum track will be as good as your own recording.
Thats funny you mention that because i was thinking about using alternative to a drums. I mainly had a snapping, and a tambourine in mind. The only problem, with snapping, i don't think i can keep it consistent long enough to cover an entire song. Are you able to do looping with the PXR4, so i could just record like 30 seconds worth of snapping, and loop that to be several minutes?
Thanks
I'm pretty sure the pxr is able copy/paste clips of sound, looping.
Or you could just use the click track to keep the tempo constant.
When I recorded my percussions, I usually laid the rest of the song first and then the beat based on that. Kinda weird but nothing to do if you gotta do it all alone :D
Cool, yeah maybe i should record the percussion last. A bunch of the stuff i wanna record is more moody sounding, reminiscent of Jerry Cantrell, Alice in Chains or Radiohead acoustic work. Can you recommend any other forms of alternative percussion that would suit this?
Yo Slapops! You sent me a PM, and I answered you, but you didn't answer back. Still want the CD? Send me an address.-Richie
