paperhatrecords
I'm self-producing my own music and I have several question regarding how I can get the best mix on my music. The music I make is very dense and layered, lots of vocal harmonies, varied instruments and polyrhythms, kind of weird and experimental art-pop. My gear is rather "budget" - I use a Tascam Portastudio 414 as a mixing board/pre-amp into my computer on which I use Magix Audio Studio 7. I use a pair of SM57s to do most of my micing, and I sometimes plug electric instruments in direct, sometimes mic an amp, depending on the kind of sound I want to get. My speakers and headphones are ok, but they are nowhere near studio quality.
The questions:
1.) Because my mix is often very dense, how can I use equalization to make certain elements have more depth and emphasis (specifically drums and vocals)? They sound very flat compared to other productions I listen to, and I'm not sure if it is the mics, the eq on my four-track or the way I'm mixing on my computer. Or is that something that really comes out in the mastering process? I'm not expecting studio quality, but I would like the final mix to sound a bit less flat.
2.) I recently read a quote from proto-electronic musician and producer Raymond Scott saying that mixes should be done at a level where the sound is barely audible. This is because when you mix at loud volumes, everything blends together, whereas when you mix at low volumes, you can hear what is too loud and what needs to come up. I usually mix at loud volumes (too loud probably), because I can't hear all the elements at low volumes. Is Scott correct - at what volume do professionals mix at generally? (Perhaps that could solve my problems in question 1).
3.) When mixing, is it better to fine tune each element's equalization until it sounds perfect and forgo a final eq, or is a final eq a better approach to finishing the mix as each element's eq would invariably be altered by a change in the final eq anyway?
4.) I really hate that I have to use digital recording in order to build the production that I want, but I was wondering if sending the whole final mix down to my Portastudio, and then sending it back to the computer would get a significantly noticable analog feel? Should it be re-eq'd digitally if I were to do this?
Thanks in advance for your answers.
The questions:
