Setting Recorder Gains?
  • Thread starter Thread starter Wabatuckian
Wabatuckian
Wabatuckian
Active member
When you set your recorder's gains prior to recording, do you set them as closely to how you want the finished product as you can get, or do you set them to concentrate on one particular track; ie, vocals, guitar, with the rest in the background for reference?
I set my levels to make sure I have a clean signal and don't clip going in. Since digital is pretty clean, you can increase the gain level of the recording during mixing. I think you stated you are using Reaper. You can look up how to do that post recording. If you clip, you can't fix it. Main focus is your levels not hitting red.
Are you asking if you set levels to reflect their final mix position - so maybe a tambourine/shaker that is just audible in the mix gets recorded really low - so a fader set to unity on playback is the right level? - That's a no. You should always seek to optimise signal to noise - so the loudest an instrument will play should nearly be maximum - red light for danger. In practice - I tend to record anywhere between nearly max and about half way on the meters. Digital makes noise not that much of a problem and a bit low here and there doesn't matter. If you deliberately record very low and then for some reason need more level unexpectedly, up comes the noise when you 'repair' it.
I was just saying in another thread how I had my vocal gain cranked up from a previous mic, and it clipped the hell out of the waveform on this new mic I got the other day.
Reaper's easy to use for gain adjustment; I just didn't know if there was a preferred method for recording other than not clipping.
Edit: So just set everything right below redline?
And, one more thing: on this unit, it doesn't let me set the gains while actively recording, unless I'm doing something wrong. I have to stop the recording, set the gains, and start again. Normal for these recorders?
Set the input gain below 0 at peak. So you loudest part doesn't clip. Take a few tests when you are setting, get your mic distance set, you vocal level set (how loud your voice is) and do a few takes and make the adjustments between takes. Once you have it set, you will just know. I know I have all of my input levels set and don't often touch them. But it took several tries before I knew which mic required what level input settings.
Check to see if the waveform is truly clipped. A 32bit float recording may contain sample values beyond nominal unity that can be scaled down while preserving their shape. Select the track and try normalizing it. At 32bit float, you may just be looking at a visual representation rather than the true waveform level.
It's still possible to overdrive the analog preamp. It's just that the AD converter should preserve the output of the preamp rather than chopping it off.
I come from the time of tape and recording a live band or show was a nerve wracking exercise! My mic pres were Triodes with a 300V supply so never likely to clip but you only had a dynamic range of 50-55dB and tape noise was an ever present issue. People say today "tape gives a nice compressive overload" I say "largely bllx" Tape distortion might have been acceptable on a rock guitar or snare but not on acoustic piano or a solo voice and massed voices sound dreadful with even tiny amounts of distortion. "Fader riding" was the skill required.
I recorded a live band about 10 years ago with an AI and laptop. I set my stereo tracks at about -25dBfs and did not allow peaks beyond -10dBFS. You can always bring stuff up digitally. (24 bits 44.1kHz)
Dave
You just need a good strong signal, which stops a bit short of clipping.
Don't worry about any specific level, just avoid the clipping.
