I'm hardly unbiased, but I try to keep the mastering it's own step. I don't even master my own mixes (but that's for another thread).
However, there are a few schools of thought on mix levels - If you're sure to stay digital, there's nothing wrong with mixing into the "red zone" (without clipping, of course. And without limiting, or compressing for the sake of volume). I try to keep the room level at around 80-85dB (arguably the most accurate level to mix at) *most of* the time.
On mix levels, I assume an analog mastering pass. So, I set mix (and tracking) levels to not exceed -6dBfs at any time. I don't care a whip about RMS levels during tracking or mixing. IMO, many people waste far too much energy trying to get hot mix levels. Inasmuch as the volume becomes paramount and in the front of the mind, the rest of the sound gets compromised. I've caught myself doing it several times back in "16-bit-land," and regretted it almost every time. In 24 bit, you can have your mixes PEAK at -47dBfs and STILL have higher resolution than a 16-bit CD. So you're really not gaining much of anything by pegging needles.
Anyway - The -6dBfs thing is a two-pronged approach... One thing is that it will effectively avoid D-to-A reconstructive distortion during the analog mastering pass, along with leaving the plugs a bit of headroom.
The other, arguably more important part is the efficiency of the monitoring chain - Listening to a mix that's more conservative in the levels makes you turn the volume up a little.
What most people forget about is that you're not turning the volume "up" - You're turning it "less down." A volume control attenuates the signal going to the amp (I'm sure you know this, but I'm trying to drive it into the brains of those who may not have thought about it that way). When you crank it a bit more, you're letting the amps run much more efficiently and with a cleaner, more dynamic signal. Which, in a perfect world, would be where it should be *after* mastering.
Anyway, so you've got your excellent, dynamic sounding mix mixed down to a stereo file. THEN I'd open it up as another VIP and start messing with dymanics to get that "sheer volume" thing going.
Um... So, to answer your question, "yes."
