formerlyfzfile
MadAudio ........
I was always under the impression that different speakers on the same cabinet were essentially different sources if the mics are right on the grill.
Assuming some isolation between the mics (a closed back cabinet perpendicular to the cab being mic'd has worked for me ...... with no room mic) the 3:1 rule is kind of uneccessary .... isn't it?
Also Januian, you say that you want to capture the true sound your hearing from the cabinet ....... the art of recording.
Dont forget to consider WHERE you are hearing that sound.
If you like the sound from standing 5 feet away from the cab, then putting a mic on the grill is not going to be the same ...... probably not bad, just different.
Like sile2001 said, listen through the mic ....... to expand .....if you want or need to put the mic on the grill ...... put your ear right up to the speaker (AT LOW VOLUME) ....... in fact put your ear up to all of the cab's speakers individually and you will notice that they sound different.
Pick the one(s) most suitable and and then try it.
The closer the mic is to the cone the more EXACTLY the placement will alter the sound ..... i.e. center cone vs. outside cone.
If you really like the sound of the cab in the room then consider putting a mic out in the room ....... the 3:1 rule does apply here.
I have had pretty good luck recording Mesa rigs.
Experiment.
-mike
Experiment.
-mike
