legionserial
Sil chipset causes pops and clicks
Ok so I've been having problems for a week now. I seem to have isolated what is causing the issue to some degree but not how to fix it.
It all started with my delta 44. And getting a bunch of pops and clicks. In my computer I have 2x160gb SATA drive, and a cheap 5400rpm IDE drive.
I discovered that if I have my project files on the IDE drives, the pops and clicks go away.
I have come to the conclusion that its the Sil RAID controller interfering with things. I am trying to run my SATA drives in a non RAID configuration. I previously had them striped. I have deleted that RAID set. I now have them as two separate drives, but it still wants to run through the raid controller, and I stil have to install the raid drivers when running windows installer for it to see the drives in the first place.
Is this normal? I'm afraid I don't completely understand all of this stuff. I just want to run my drives as normal hard drives without all of that RAID bullshit, which is clearly fucking everything up. lol.
Is there anyway I can run the 2 drives as two separate drives without all this rubbish? I am reluctant to use my crappy old IDE drive, but if its not possible to use my SATA drives for audio without a serious degredation in sound quality, then I guess I will have to do that and eventually buy a good IDE drive and smack my SATA drives with a hammer....
Oh, I'm using the ASUS A7N8X-E mobo with the Sil 3112 controller.
If anyone has any idea how I can do this it would be much appreciated
