G
got_metal
Need a little help here....I just installed Samplitude v6.0 Master last night. When I try to play the demo track, I get an error message that reads:
"Cannot open waveform output device 'Realtek HD Rear Output'!
Reason: The specified format is not supported or cannot be translated. Use the capabilities function to determine supported formats."
Can someone translate that for me in simple-ease? I'm guessing the problem is because playback is set to 24-bit, which my soundcard doesn't support? But if that's the case, there has to be a way to change the bit-rate to 16. BTW, the manual didn't help. It talks about changing the bit-rate, but isn't very clear on how to do this. Thanks!
...yeah - I'm basically what you would call computer illiterate. But I guess did mean "bit-depth".
