sampling rate w/ delta 66
  • Thread starter Thread starter synergy
synergy
After running a wave profiler and setting the driver bit depth to 24 and restarting cakewalk, it tells me that none of the omni's inputs are compatible at the current sampling rate? Can anyone suggest a solution? I just got the Omni, but I'm pretty sure its capable of this. i'm using the newest wdm drivers (5.12.125).
thanks
YOU HAVE GOT TO GO INTO THE DELTA MIXER WINDOW AND CHANGE THE SAMPLE SETTINGS, ALSO MAKE SURE YOU HAVE CHOSEN THE DRIVERS IN THE THE DRIVER SET-UP WINDOW IN SONAR
ALSO IF YOU HAVE OTHER PROGRAMS UTILIZING THE DELTA DRIVERS THEY MAY NEED TO BE DISABLED
