B
blacktrop
Hi all, it seems simple, and maybe it is, but I cannot seem to figure this out... Here is what I am working with in this case:
Synthesizer (MIDI IN and OUT
rack sampler (MIDI IN, OUT, THRU)
rack arpeggiator(x2) (MIDI IN, OUT, THRU)
midi thru box (casio tb-1)...(MIDI IN and EIGHT THRUS)
OK, so I would like to play a sample from a line in source into the sampler, then map that sample across the synth (that part is easy, of course); then I would like to be able to arpeggiate the sample. Is this possible (MIDI-wise)? It seems as if it should be...
My other (related) question is, how do I use the two rack arpeggiators together with my synth? So far, I have only been able to use one with it (simple Synth to Arpeggiator MIDI send/recieve)...
Basically, I need MIDI connection help.
ANY HELP WILL BE GRRRREATLY APPRECIATED!
THANK YOU!
THANK YOU!
