Sample rate freakyness??
  • Thread starter Thread starter JimmyS1969
JimmyS1969
JimmyS1969
MOODerator
I recorded an acoustic project last night at 44.1, or so I thought. I used a TC Gold Channel preamp (digital out). Project played at correct speed while recording/playback. Exported files are playing back slow. Now when I opened the project this morning, even Cubase is playing the tracks slow. :confused:
What do I do to get it playing at the correct sample rate/speed? 'Project Setup' shows 44.1. I tried changing to 48k but it still plays slow. Audio files in Pool are also showing 44.1.
I have already screwed up a the project folder by trying un-undo-able, sample rate change operations. I did a 'Backup Project' before, so I still have what I started with this morning. :)
Any Ideas? I've never messed with sample rate issues before.
Sounds like the clock on the TC was set to 48kHz even though Cubase encoded the audio to 44.1. Try changing the sample rate to 48kHz in the project setup and when it asks you to convert files, say "no". Also, if it asks you to keep the audio at sample positions, select "yes".
Cheers :)
No worries. This has happened to me before too.
Cheers :)
