TelePaul
J to the R O C
Is tehre anyway to remove rust and oxidizing marks on things like pickup selectors, machine heads and screws?
Flangerhans said:Naval jelly...as bad as it sounds, it works great. Be careful, it is very toxic and should be treated with respect.
A lot of times the results from attempting to remove the gunk from plated metal results in a worse look. Plated parts that are cast like machine buttons or casings have microscopic pits in the base that cause oxidation. The cheaper the part the worse they are in most cases. The result is that they "blow after awhile. The normal base on those is a flash copper then bright nickel and then the chrome, gold whatever. The pitting is in the base casting so be careful if you attempt to clean it too aggressively as you'll just wear off more of the plating. Ditto the screws and small parts. They are "barrel plated" which means they are done by tumbling them by the bucket load and the finish is not too good/durable. Sure it looks fine for a while but it soon wears. The only sure way to get a long lasting consistent finish is to get them plated yourself. A visit to your local platers may pay dividends because they can stick small parts through with their normal run for a six pack and a smile. They just wait for a job with the same spec and wire it onto the jig as it goes round. Ask them for a good "leveling" nickel base. Also you need to find a platers that specialises in precious metal finishing. Some are more down the larger chrome and base metal route. The two don't really mix.TelePaul said:Is tehre anyway to remove rust and oxidizing marks on things like pickup selectors, machine heads and screws?
