Hi,
This is not realy recording related, but this looks the best forum to ask:
Is there a way to run several plugins (DX and/or VST) without running an audio application? I would like to use a spare pc as active cross-over filters for experimental loudspeakers. So ideally I need a small program where you can select an input, an output and put some plugins in between. If there is an program that allows this, fine, just let me know. This pc has to run unattended, so once set up, only the powerswitch will remain, so I dont want complicated loading procedures (if possible).
