Hi all, I'm pretty new to acoustics and am wondering about my current room layout and If it may be causing problems even before I start treating the room. From what I've read so far symetry, it would seem, is important. Here's my current layout. I use the room for both recording and as a control room.
As you can see the room is pretty small, and because the listening position is on a sofa, everything is quite low. Will that in itself cause problems? It also puts the listening position and the monitors below the bottom of the window. I'm going to move the table to the other side of the room so I can move the sofa more into the middle.
Anyone got any suggestions as to how I could make this better?
Cheers,
Ian...........
Cheers,
Ian...........
