Changing the response of a room via EQ is basically impossible. The best you can hope for is to make the speakers less accurate to make up for frequencies the room can't handle for whatever reason.
The way to fix a room is to fix the room.
im gonna use it to find the spots i need to fix and try to fix them with room treatments.
Agreed, however if you are on a budget or using stereo speakers, computer speakers, or cheap monitors it may be better this way. You are adjusting the speakers to your room, not the room to your speakers so you'd be turning a speaker that is coloring the sound into a "flat" speaker.
EQ'ing a speaker for preference is completely different than trying to EQ out the limitations of the space - which is impossible.
Even *IF* you could EQ a speaker into "accuracy" (a reasonably flat response), (A) you can bet that it's going to be flat with only a particular input (pink noise for instance) at a particular SPL.
