Roland TD3 with PT and Reason3
  • Thread starter Thread starter hornedrum
H
hornedrum
Hi there,
Just bought a Roland TD3 sound module and want to use it with MIDI and rewire to trigger Reason's Redrum.
Most of the sounds the TD3 creates are outside the C1 - C2 octave so don't triger any sounds in redrum.
I only have one pad right now as input for the TD3, but it doen't seem to like it when I try and change the MIDI note number for each pad: nothing changes.
Is there any way I can re-route redrum for midi input so I can trigger every sound from the TD3.
Or is there some way of changing midi mapping(?) in PT to reflect this?
I know I could record a midi track then manually change each BD, SD onto the right note, but that defeats the purpose of buying the TD3: ease of playing in kit parts!
Any help gratefully appreciated!
Cheers,
Andrew
What I would do in your situation, though AlChuck may have a better suggestion, is forget the ReWire-ing and plug the TD3 straight into Reason.
Then set the notes in the TD3 brain so that they jive with the ReDrum kick, snare and so on.
Then get the Reason metronome going and play the part.
Quantize if necessary, then export a midi file which is going to contain EXACTLY what you played into Reason.
