The question on the limiter is when cutting a vocal part, the input is strong and stays around-4 and does not go above that level but, when it is played back it peaks a lot higher. I understood a limiter to eliminate any peaks that you set it for. I do not understand if i record at a steady level why my recording should peak high.
