well, would it matter if you ran it through a tube preamp such as the dbx 386? or would this be too much tube sound? i'm completely unfamiliar with tube mics/preamps apart from what i've read and researched. any info is appreciated...thanks
Even though the 386 has a tube in it, it has very little "tube" charecter. I consider this to be a very clean (not the cleanest) mic pre. Something like a JoeMeek on the other hand could possibly be over the top but that's just a matter of opinion.
I use an NTK with a Joemeek VC6Q, it sounds fine to me...Depends on what you're recording, and your personal preferences.
You really have to listen for yourself
I A/B'd the NTK against the new Groove Tubes GT66... I found the 66 to have a beefier sound over the NTK...plus the signal was much hotter then the RODE. So, you may want to look into the 66! Again, a lot of it has to do with what your personal preference is and what type of recording you plan on using it on.
