The most recent few times i've seen an NT delivered it's came with one shock mount and a 3/8 adapter, i'm not a huge fan of the Rode shock mounts to be honest, they're good for about 6 months (after being extremely careful) but they start to loosen up after that and take some regular maintainance to get them to hold still. But anyway, the specs below, enjoy.
Capsule: Externally polarised 25mm (1-inch) condenser.
Active Electronics: J-FET impedance converter with bipolar output buffer.
Pickup Pattern: Cardioid.
Frequency response: 20 Hz-20 kHz.
Output Impedance: 100 Ohms.
Sensitivity: -31.9dB re 1V/Pa (25mV @ 94dB SPL) +/-2dB.
Equivalent Noise: 5 dBA SPL (per IEC651, IEC268-15).
Maximum Output: +13.7dBu (@ 1% THD into 1K ohm).
Dynamic Range: > 132 dB (per IEC651, IEC268-15).
Maximum SPL: 137 dB SPL (@1% THD into 1K ohm).
Signal/Noise: 88dB (1kHz rel 1 Pa; per IEC651, IEC268-15).
Power Requirements: P48, P24 phantom.
Packed Weight: 820g (Mic only 326g).
Mic Dimensions: Diameter: 50mm Length: 190mm.
Packed Dimensions: 140 X 110 X 320mm.
