I've never tried reseting the whole board, but as far as I know you can't.
However you can reset your templates, which basically ends up resetting all of your settings. At the left of the screen, there are + and - symbols under the library setting. If you switch that while looking at the screen it will tell you a different template name, and when you find one you want to try hit recall. Boom, all the settings are switched.
But before you do that, save the template you have. Because when you switch to the factory templates, all your settings are gone, inputs, outputs everything. And if you suddenly can't get something to work, its handy to look back at how you had it setup before when it did work.
