Rephrased question
  • Thread starter Thread starter guitarmonkus
guitarmonkus
guitarmonkus
Situation:
I'm getting into home recording. I am not good at the drums, but need them for my songs. I live in an apartment, so getting an acoustic drum set isn't very realistic.
I want to look into an electronic drum set simply to add basic beats to my songs, but I want to play them all myself.
Is there a standard "go-to" electronic drum set (like the Shure SM-57 for mics)? I don't even know what parts I need to make this work. I posted a few minutes ago and a guy was talking about a DIY, which I'm clueless about. Assuming I know nothing about playing/or connecting an electronic drum kit to my computer, what are the components I need?
I know I sound like an amateur, but I have to start somewhere. Thanks.
First off, what's your budget?
I don't know a lot about e-drums but what I've read is the kit and the module make all the diff in the world.
http://www.yamaha.co.jp/english/product/drum/dtx/dtxpress/
I dunno if these are any good but some reading will help you in your decision maybe. Oh, and read some about the triggers and modules available...might help...
Luck to you..............
Oh, and I just noticed there's a few threads talking about e-drums....I read thru some of em. Good stuff. Should help... :D
I have around a 600 budget. That's going to cover from my drums to my audio interface.
What's a trigger? A Module?
Sounds like maybe you need some terminology to start with:
A "trigger" is a device which senses impact and converts it to an electrical pulse. There will be one or more trigger in each electronic drum.
A "module" is a device which converts the impulses from the triggers either into a drum sound, a midi message or both.
Modules will have several input jacks in them to run a cable in from each trigger, and usually have a way to adjust for things like input sensitivity, etc. They will also allow you to assign the various built in sounds to each channel.
Popular sets such as the Roland v-drums have modules which have some pretty good built in sounds from my understanding, but the price tag on the whole set-up is going to be higher than your budget.
I am in the middle of these issues myself. I'm a guitarist and recording hobbyist who wants to try edrums for tracking (tired of trying to program drum tracks in my sequencer). Like you, I don't want to spend a lot of money, I just want something that works. I do have some pretty good drum samples in my pc (I have Gigasampler) so I really don't need an expensive module with built in sounds. So here's what I'm trying to do - maybe this would work for you:
First off, I just purchased a used Roland PM-16 ($100 on ebay, it arrived today :D ). This is an older unit which is now out of production, but should work fine for my purposes as opposed to the new modules which start at $400 and go up from there. It has no built in sounds, but what it does have is inputs for up to 16 triggers as well as midi in and out. Each trigger input can be assigned to transmit a different midi note. This will be connected to my pc via my usb midi interface. I will load up a kit in my gigasampler to play the sounds based upon the midi messages coming from the PM16.
For "drums", I'm going the do-it-yourself route, using Remo practice pads which I will modify with cheap Piezos (triggers) and a few other miscellaneous inexpensive items. The pads cost between 12 and 18 dollars each from Musicians Friend and with the additional parts should run between about 25 to 30 dollars per drum. There are instructions on the web for making these, do a google search, or go to www.electronicdrums.com. I plan to make a rack to mount these on using ABS pipe and PVC fittings. I'm working on a scheme to mount the drums using inexpensive hardware available at Home Depot.
When all is said and done I expect to have full e-drum capability for much less than your budgeted amount of $600. The only other option I've seen in this price range is the Ion set which runs about $300, but in my opinion that looks like a pretty flimsy setup. My set will be much more sturdy and have a lot more drums for not a lot more money - it's just gonna take a little work.
Well, hopefully that clears a couple things up for you and gives you some ideas. I've rambled enough for one post, but if you have more questions or you're interested in hearing more about my edrum project, let me know and I'll ramble some more :cool:
Now that's a response.
That cleared up a lot. Thank you very much.
I don't have the skill or patience to do what you're doing, but kudos man.
I'm just going to buy a complete kit that sits somewhere in my price range. Hopefully it'll be to my liking. It won't be fancy, but maybe it'll be enough to give a drummer friend of mine the idea for parts without going crazy.
Again, thanks man.
T
Replies
9
Views
872
Maya Clars
Maya Clars
B
Replies
11
Views
1K
BaronEstelle
B
C
Replies
23
Views
3K
Old Music Guy
Old Music Guy
