D
		Dark Fader
kensington...  about recording analog and dumping it to digital...  A lot of people do it.  I wrote a whole big argument in the computers and soundcards forum about sample rates and why digital is kinda bad for ultra high frequencies, but we all know that first of all, our finished product is digital anyway, and we still think it sounds good.  So it really don't matter that much, though i'm still for 24/96 audio.  The fact is, most people who use analog use it for the COLOR.  Its kinda like a good mic pre, it has its own sound.  I was listening to radiohead's KID A through my new yamaha msp5's and I heard this distortion on all the cymbals and high hats...  and i thought, "ya, that's analog tape, pegging the meters." It just sounds like phil the drumme was really whacking the drums. (actually, to my ears it almost sounds like bad mp3 compression, too, only way cooler.)  And rock is a pretty analog sound, really.  It was born on analog.  If you are using a good sound card, the conversion isn't really a big deal.  And by "good" here i mean not a consumer card, like a soundblaster.  I've read and heard that a lot of the pros will track in analog for the sound and the color, then dump to pro tools for editting and plugins and mixing automation (oh what would i do without it!) and them mix to digital.
Here's another explanation. Tubes distort, and people like it. What it does when it distorts is it adds either even or odd harmonics (i forget which) to the signal. Tape adds the other one when it distorts. Just a little bit of this colors the source and makes it a bit richer and stuff... And once its in there, you dont' lose it when you dump to digital.
I also know from experience that punching in on analog is a heck of a lot harder and riskier.... you need a bigger gap to pull it off than you do with digital. And there is no magic Control-Z undo button on tape. Ouch.
About the soundcraft... I think I may be able to answer some questions. I have used a soundcraft K2 extensively, and soundcrafts in general are quality, quiet, good sounding boards, which the noteable exception of the soundcraft series 100, which absolutely reeks. Don't touch them with a ten foot pole. It was the first unit they ever made, and oh goodness were they bad. Anyway, the K2 that I use is a 48 chanell 8-bus baby with a matrix. the matrix really comes in handy, check to see if you get that with the ghost. At any rate, the K2 is also "automateable" as far as mutes are concerned. There's kinda two ways to do this... You can assign a mute group to any one of the 8 quick-access mute group buttons or 127 not-as-easy-to-recall memory spaces. Then when you want to mute say the brass section (or anything on mulitple channels, assuming you already programmed it into the board) you just hit the "mute 1" or whatever its called button. Very handy for live use, for sure. The REALLY REALLY cool thing about the board is that it has MIDI ports in the back, and every time you hit a mute or unmute it sends out a midi message. THis is great for live productions because you can import a song into a sequencer like sonar or something and record all the mutes in time during practice, and then al you gotta do during the performance is hit play on your sequencer, and the mutes will just happen. its a great feature. I'm expecting something similar on the ghost board. Check a manual off of their website for sure, though. This makes life tricky for anaolg guys... because you run into the same stinking problem i had... you gotta sync your tape to your pc. which requires buying a $130 box to do it... and the software that will support it. Anyway, check it out from soundcraft for sure, but that's probobly what it is. they are still really good boards.
