mitosis
I recently purchased a Yamaha MG10/2 to do recording with and I have a couple of questions. Which is the best output for me to choose from the mixer? I have the choice of REC OUT (RCA L & R), STEREO OUT (1/4'' L & R), and CONTROL ROOM OUT (1/4'' L & R). I am currently choosing the REC OUT and going into a 1/8'' Line In on a Creative Soundblaster Audigy II sound card.
Also, correct me if I'm wrong, but to set the levels on the mixer, you should start with everything at zero, then produce sound at the source (ie, the mic) and then raise the initial gain volume until it peaks and then back off on the gain until it only peaks occiasionally. Then you should set the master fader level and then open up the main channel volumes until you get a good mix. My question is, how high should you set the master level; until it peaks and then back off, to the little arrow on the notches on the knob, or until its about the same volume as other songs on your computer.
Also (sorry), but I'm miking drums right now and when I try to set the initial gain levels for the overhead condensor mics, the peak indicator shows that it is always peaking anytime there is sound. I even turn the initial gain levels all the way down and it still shows the peaking. I eventually just ignored it and choose a gain level that sounded decent although it said it was peaking. Is this a problem or should I just ignore it?
Thanks
-Nick
Thanks
-Nick
