Johnny Nowhere
Recording with compression is old school, and these days it's better to record straight and add compression and most other effects later when mixing. In the old days of analog tape, the limited dynamic range required compressing when recording. If a singer got too loud the tape would distort. And if they were too quiet on a soft part and you raised the volume (or added a compressor when mixing), then you'd also raise the tape hiss enough to be bothersome.
These days even 16-bit recording is 20-30 dB quieter than the finest analog tape recorder. So there's no need to compress when recording. As Boulder said it's not outright wrong, but why risk recording a "squashed" sound that can't be undone later? If you want to hear the compression as you record, which is a good idea, simply patch it into the playback path rather than the record path. This gives you the best of both methods: you hear the compression but don't actually commit to it.
--Ethan
I'm sorry but I disagree with Ethan's statement entirely. I have chosen to continue to record in the analogue domain for years and compression is not used to prevent 'tape distortion'. It is primarily utilised as an insert effect to smooth vocals. Limiting is used, but only in order to prevent clipping at the board, where most distortion occurs. Tape, when over-saturated, results in a physical phenomenon known as tape compression.
