Is there a trick to control the gain on a mixer/soundcard combination so that the soundcard can pick up the sound of (say) a guitar both when I'm gently fingerpicking and when I'm wailing away during the same session?
At present, if the recording volume is set to that fingerpicking comes through, then when I start wailing it'll clip like crazy. Conversely, if it's ok to wail on, then it won't pick up the finger picking.
to solve this problem, I've connected TWO cables to my guitar via a splitter, and sent one cable to a high amplification channel and another to a low amplification channel, then sent both channels into my soundcard as left and right, so when one channel isn't picking up due to clipping or inadequate volume, the other one is usually working.
this poses a few problems, not the least of which is having to go back and manually merge the two together, I'd much rather if theer were an auto gain control of some sort that I could employ. Is there such a beast, either in software or hardware?
-Alex
-Alex
