HI SMoovdj,
On vocals I usally record directly to TAPE,(lol... Tape is a 6 gig hard drive) useing dynamic exfixs and EQ. This is not something you want to do unless you are pritty confident you can get the sound you want.
I usally go EQ into the compressor then into any weird stuff like deSors or excitors.
My EQ settings depend on the person singing of course, but I uselly boost everything a little and cut the low mid about 5db at 700hrz.
The lows, high mids, and highs are all boosted about 4 to 6db. The fequency I like to boost in the lows tends to crawl around 200hrz to 240hrz. As for high mids I like to boost something like 2800hrz to 3000hrz this is an important area cause the High mid is very audioable to human beings play with these fequency you'll see the bigest change in you tone. As for the highs I boost around 4db 6db at 5khrz to 6khrz.
With the compressor I like to just reduce the dynamic range a little, there is always time to crush the signal in the mixdown.
Also I agree with hornet. Choose the right mic, and a good mic pre-amp, it can make your tone bigger, pluse sometimes if you have a good mic-pre, will help reduce noise.
Or wont produce much noise I should say.... lol
Im sorry I didn't mean to chew your ear off.
P.S.
Practice around with these ideas, you don't want to try this in a real world situation until your confident with doing them. Once your through to tape your stuck there is only so much you can do in mix down. The practices I posted are what I do just to help the whole recording session go more fluidly and I also get a better sounding product doing things this way.
Also pardon my spelling, I need to stop buying these ausio toys and buy a spell checker lol...
Good Luck,
Signa1
