Recording too hot
  • Thread starter Thread starter rgraves
R
rgraves
OK someone help me out here, using a DAW what exactly is the "ideal" recording level? And what does it mean really to record too hot?
I mean I know obviously any clipping at all is going to ruin the track, but using my 1820m EMU and marshall amp, and AKG vocal mics, I have never had to turn my preamp much to get to like -6db to -10db...I always have lots of headroom left. All things considered, what level is it best to aim for?
Also, I never quite understood what happens with all the levels when all the tracks are combined...let me explain myself...I mean if you record everything at -6db and then combine like 20 different tracks it ends up clipping the total output right? and then do you just turn everything down from the master output?
Someone help me understand what the best way to do it is...
Usually, -18dBfs is nominal 0dB. So if you're turning your preamp up to produce -6dB in your DAW, the preamp is outputting at around 12dB over its designed optimum level. With a less-than-stellar pre, this is already degrading your sound. Also, -6dB is just a hiccup from digital distortion, so you'd need to watch your levels like a hawk. As you have noted, multiple tracks at that level will have to be turned way down to avoid overloading the masters.
Aim for -18dBfs.
This is a question i have been thinking about myself. I seem to have levels good when recording tracks, and nothing really clips on my mixes, but the master clips, and that ruins the mix. I feel extremely limited to my mixes based on the levels i had to start with. I have used compression, and still i cant get that master fader not to clip. When i bring everything down, the music is too low. I then throw the stereo image of my tracks in the t-racks mastering program to bring my levels back up, and this still doesnt help as much. I have my drums invidiually miked going into a group fader in cubase le. The indiviudal drums are fine, but the group fader is hard to control. I even compressed the indiviudal drums, but when i compress the group it sounds squashed and low. This is the the same with bass guitar, its hard for me to get a good level. As with my guitars too, i dont know how to get them loud enough without clipping. Any suggestions?
i also always wondered about this. I record my stuff going from a anolog mixer with all the faders at 0, and turn up the pres on the anolog board untill the loudest peaks hit 0 on the mains of the board.
but when it goes into my DAW (Sonar 4), with all those faders set to 0, it reads at -6db?....or something like that...............
i guess thats too hot huh?
I record everything I do digitally to hit no higher then 0db on my meters. What you don't want is flat line or bury your meter in the read zone.
Often when I start getting some kind of weird clipping and nothing is going over the red. It usually just a case of 2 instrument that are clashing.
What you have to do is find out which instrument are causing the problem.
First go to the part that is consistantly making the clipping noise and put it in a loop that concentrates the clipping. Then mute an instrument. Did that stop the clipping noises? If not goto the next instrument and do the same until you find the culprit.
Usually when you found the first one it not had to tell what the other one is. For me it seem most likely occurs when you got 2 instrument in the same frequency range causing pops and clips. Like a bass guitar playing over a kick at the same time.
I do not have a one word answer to fix the problem. You will just have to experiment with like maybe cutting away the bass either phyically or maybe trying some eq and taking away from the common frequency of each instrument.
Somebody else may have a better approach, but I think you get the idea.
Huh, I think the last poster must not have understood my question...
All I was asking is when recording, in my case probably a 15-20 track session in digital (cubase) what is the "ideal" recording levels?
I would think this would be a one fit for all answer because it seems to me it's just as easy to get -1 db as -20 db and I've got lots of headroom still left, especially when using direct in and keyboards and non mic'd stuff.
But let's say I am going to record drums, keyboard, distorted guitar and voice.
I usually have the guitar player play the loudest fricken possible so that I know he won't go over that even if he tries...same with drums,keyboard etc, voice is different obviously, have to be careful on that one. But I never have any idea what the max volume I should hit is?
Should the maximum volume hit -6db? Should it be less. Shouldn't I try to get as much of the original signal as possible without turning up the preamp?
I think the lowest possible I could get with my preamp turned all the way down is about -18 db...
Thanks for helping me in this question
Sorry I was referring to some other post above mine.
In my opinion. It's probably best to record the signal as hot as possible meaning that your peak and transient in your music should just hit at 0 db without going over. Basically do this for everything, voice,drums,guitar etc...,.
Basically what happens if you start recording things lower there is a probability that you will have to bring it up in the mix. In which case anything you mix higher will also bring up the noise floor for that track.
More noise basically means your song loses a certain amount of clarity in the mix, unless your ok with your music sounding very quiet. Then I wouldn't recommend this route.
Look at this way once it recorded you can bring it down on the mixer. Which will also bring down the noise floor.
All that is important here is the meters are not clipping!!
Anything that goes through a preamp like mics and guitars should have its out be recorded as hot as possible.
Keyboard and Synths are usually pretty hot normally and can go in direct.
If this is true you have a problem with the gain staging somewhere. Checkout how you have the Emu hooked up. The following specs say you have a software selectable option which may be the source of your problem:
-Professional: +4dBu nominal, 20dBu maximum (balanced)
-Consumer: -10dBV nominal, 6dBV maximum (unbalanced)
Oh, well yeah that's true I have it set to consumer -10dbv. It looks like that only affects the keyboard inputs though...the guitar inputs, and mic inputs all go through the preamp which is always set at pro.
So, from the previous post does someone else concur that it's best to get it as close to 0 db as possible when recording each track?? I wouldn't try that with vocals I think because it would be way easy to go over, but I could probably do that with every other track...I just thought I've heard opposite ends of the story, I wish someone with lots of experience would confirm this for me.
THanks
You want to get it close to zero if you are recording analog with a Vu meter. For digital with 24bit you want it around -18dbfs like ermghoti is telling you.
I really think it's not that important to pay too close attention to DAW meters. Use your ears, if you hear digital clipping, turn it down. If you have optimized your monitoring system and you know the dB(SPL) level it puts out when your faders are at unity, then you should be okay. If you bounce your mix and play it on your home stereo or in your car, and it sounds way too low, or way too hot, that will tell you something.
Oh, OK, how about if I'm recording 16 bit...should it be a different level?
Or should I just change the recording to 24 bit if I want to make a better recording? I thought there where a couple threads were some people say it's the same to record 16 bit or 24 bit, in the end it turns out the same??
It seems very odd to me to record at -18 db, maybe that's because I'm doing 16 bit...it just seems that -18 db is way too low, I mean I wouldn't hardly have to turn my preamp to 1 or 2 out of 30.
well i know that 16 bit and 24 are supposed to make a big difference. Its the 44.1 and 96k people wonder about.
I am using My firepod and cubase Le, and i want the most of my levels without clipping. I record at 24 bits. I have everything hitting its max volume without going over and compressing while i record. Am i doing something wrong here. Like i said above, I feel very limited to my mixes, and clipping is really the ceiling that stops me from havign a good mix.I find imput levels the hardest and most important thing while recording because when i have good input levels, its easier to get a great mix. Should i record all my tracks max at -18db also?
Aim for -18dBfs.
So those tracks we hear on the radio and on our CDs were recorded at about -18dB? Or are "professionally" recorded tracks different?
We have to differentiate here between dBVU on the analog side and dBFS on the digital side. There really is not such thing as a "dB" without referring to some scale such as "VU" or "FS".
A very nice analogy is the term degrees when used to measure temperature. There is no suchthing as a "degree" (°) all by itself, it is only in reference to a particular scale such as Celsius or Farenheit. just as 18°C means something entirely different than 18°F, -18dBVU means something entirely different than -18dBFS.
VU is used mostly on the analog side whereas FS is used on the digital side. While there is no set-in-stone standard formula for converting dBVU to dBFS, the equipment manufacturers have settled on a de facto standard in A/D conversion that a 0dBVU analong signal going in should convert to about -18dBFS on the digital side.
As a matter of generl rote (there are exceptions), analog gear should be staged so that the signal is hovering somewhere around 0dBVU, with maybe the occasional peaks going over that by a few dB if you want to drive it hard and leep the S/N ratio down. (There are other complications like whether the VU meter is a fast peak reading meter or a slower averaging meter, but we'll ignore that for this basic post.) If one's gain staging is set correctly - and their converters are so calibrated - this would bring the signal in at somewhere around -18dBFS on the digital side, with the peaks going wherever they need to go; often as high as -9dBFS or -6dBFS if the signal is dynamic enough.
If you're recording at 24 or 32 bit - which you really should be - the extra headroom on the digital side is really something you want to keep for a few reasons. First, at those bit depths you have plenty of digital dynamic range, you really don't need to boost the signal to stay away from the noise floor. Second, you might want the headroom during mixing; if you need to raise the level of one track above another, you have that option without having to pull down the level of the other; this gets real important when you have a multitrack project in which you need to fit the tracks together without having to "domino effect" the volume on 10 other tracks just to fit one anemic track in at the top of the mix. Third is so that you have some headroom when summing the tracks down to a stereo mix. Chances are you still won't have the full headroom that you need, and you'll still have to throttle back the mix buss, but the severity of such throttling is kept to a minimum.
If you're recording at 16-bit, the "rules" change somewhat, and there you will find some folks saying that you need to record hot on the digital side because you don't have as much dynamic range to play with. This is a little bit debatable on both sides, I think. However, more to the point, I wouldn't recommend recording at 16-bit these days for any reason other than if your hardware or software limits you to that depth. If you have 24- or 32-bit capability, go with it; there's no reason not to, and your mixes will thank you for it. :)
Most of those were probably recorded around 0dBVU if recorded analog, and -18dBFS if recorded digital. Don't forget, though, that after recording comes the mixing and the mastering. In those stages the volume is typically incrementally increased so that by the time it hits the CD, often it's peaking around 0dBFS. But it's not *recorded* that hot.
HTH somewhat clear up an otherwise admittedly very confusing topic,
G.
sry again, so 24 bit, -18dbfs? What does fs mean anyhow? So I shouldnt try to get my levels up to 0.0. I try to stay in the green part of the meter in cubase, but some bass guitar slaps bring the level into yellow or just touching red. I want to have the flexability with the mixing, so headroom works. I Think i understand what you mean Glen, i just want to mix without the clipping! Thanks for advice.
Oh sry i didnt see what you said on the bottom there. So -18 it is, i will def try it out thanx.
ahhhh i see now.........my problem was i had my sound card (delta 66) set wrong. The options were professional +4db, normal 0db, and comsumer -6db. I always had it set to normal.............which is why on my anolog board it was hovering around 0dbVU, but in my DAW the siganl was coming in at -6dbFS.
so maybe i should set it at consumer, so the singal will read in my DAW at about -12dbFS. Am i getting this right? I record in 24/96 format.............
dBFS means "decibels full scale". It is an abbreviation for decibel amplitude levels in digital systems which have a maximum available level (like PCM encoding). 0 dBFS is assigned to the maximum possible level.
Remember that is a more or less average level. Your big peaks could easily rise another 8-10dB above that.
What I sould have explained better was that 0dBVU come in at -18dBFS (give or take) if you have your input mixer levels on your soundcard and software set to untiy gain (0 gain).
The idea is you shouldn't have to "set" much of anything on your computer. If you have your levels set correctly on your gear going in, they should more or less automatically come into your computer (or digital recorder) at the right levels if you do not boost or cut your input levels in your software. Don't worry about the meter readings; if your gain staging is set properly onthe analog side, that's all you need to really worry about. This is the idea and the ideal.
G.
