Hi. I just got the studio 1 plug-in, and I'm trying to record in REAPER (brand new to this). I'm struggling to get the right levels. I have no idea what to look for. Is there a trick to balancing the amp's output level with the track level on the recorder? Also where should I set the master? Basically if I set the level too low I get a faint signal with background noise. If I set to high I get ugly distortion. Should I try recording with a compressor, limiter, or both? Or should I use those when I re-mix?
I have also tried Ampitude and had better results with that. I think I got the I/O levels set correctly within the plugin. It's hard to tell until I actually record and playback, though.
Oh yeah, I'm recording w/o an interface at the moment (ASIO4ALL). Will having a preamp-ed hi-z input reduce "artifacts" - string noise, string slap, distortion, etc?
