I have played drum sessions professionally for the last 20 years or so. The kit recording setups have ranged from full-on 30+ mics in a special live room to sample triggers in a basement studio. There are pros and cons to each, but I've always tried to stay flexible as to what method gets the appropriate sound for the given piece of music.
- depending on the type of music, sample triggering can be very advantageous. Like a hard rock song where it's all about wacking the shit out of the snare. Going to a sample trigger will give the engineer much more control, and the ability to dial in the tones in exactly the right frequency area of the mix. This can transform your dead kit into a monster in the hands of a good engineer. This also gives you the option to change tones if necessary without retracking the performance.
- live kit full-on mic setup is wonderful if done right. You need a fresh set of heads and a good & settled tuning of the drums. Then you lock down the whole kit to prevent rattling, taping off hardware, putting cushions between adjacent stuff, and baffling the drums to the point of getting good tones without excessive rings. Then you mic with the
correct mic types for the job, you know what I mean there. Get levels on the close mics, then setup ambient to fill in the live dynamic. Spend the time to get good clear levels on each drum, while attempting maximum physical separation and minimizing bleed.
Then you need an excellent performance with consistent hitting velocities, locked timing, and maximum inspiration.
