C
CanopuS
Amateur music since 1847
Right, I've spent months trying to figure out a good setup. I've looked through a lot of the possibilities, and as I'm going to need to work with a laptop, I thought using a mixer would be a good option, especially with preamps etc.
I had a look at the Mackie 1402VLZ Pro, and it looks pretty solid. Can I just ask, are mixers the thing to go for? Are Mackies the best? etc. Thanks
But I'll say we're looking at approximately $500. I know, its not a lot, but its all we have
Yes, you can mix it through the mixer to a stereo. If that's the case, then all you will need is your mixer and a cable to plug 2 mono 1/4" cables into a stereo 1/8" cable. Doing it this way though, you must have your mix the way you like it when you record because once it's recorded, you can't change it except for EQ'ing. If you try to compress it, you'll find that your entire drum mix gets quieter and louder, but yes. That is perfectly feasible.
