Recording my own violin playing
  • Thread starter Thread starter eug_fiddler
good luck ... and yes check out davidk...
The brilliance of DavidK is that he works in his untreated living room, and I believe he uses MXL603s into an ordinary interface (check me on that though). He also uses a lot of softsynths, but the fiddle is all acoustic. He gets excellent results and I think his second CD is out soon . . . his first is here:
http://cdbaby.com/cd/davidkempers
Edit: I think I remember he went to a pro studio for his second CD, and used Schoeps. But that first CD is a homerec job.
Must add, that the suggestion of recording practice on tape assumes that you have a good to very good stereo system to play it back through. If your laptop's speakers or some computer sound system is what you are going to listen through, it won't matter.
I'm a headphone user... I typically use Etymotic ER-4S to listen to most of my music. Amazing headphones. :) I used to own headphone amps etc but I've had to sell most of my gear. I used to build my own DIY headphone amps and used to also own a pair of Sennheiser HD600, but in the end the Etys were just more honest and multi-purpose so those were the ones I ended up keeping for good. In any case I know a little bit about what it takes to build a decent "audiophile" quality rig.
And yes, let's stick to digital guys... I don't have the money, time or uh, determination to build up an awesome analog rig. I also want to be able to make simple videos of myself using the iSight camera on the Macbook with good audio quality. And besides most places require CDs these days, and often DVDs (Audio can be edited and faked a lot easier). I'm trying to go with the most practical, convenient solution. The priority is to use this as an aid to my practise first, and if it happens to produce good enough recordings to send off to people, then bonus!
I'm a believer in the idea that Firewire > USB, so I think I'll look at one of the PreSonus Firewire interfaces instead of the MAudio USB box I mentioned earlier.
MSH great work by the way, I used to run a similar sort of "homebrew" business myself building headphone amps and cables etc, so I totally sympathise with what your'e doing!
Hi guys, just joined the forums...
Basically I'm a professional classical violinist, and want to start making high-quailty recordings that I can use for audition tapes, and for my own personal use (recording yourself is so useful to really hear what you're doing, etc..).
In the past I've used a MiniDisc recorder with a Sony stereo mic - I want something a lot better sounding than this.
I was thinking, for a start, to get a basic USB interface for my Macbook, and I guess a pair of mics??? I obviously have no idea how to do this stuff, but in the past when I've had people make recordings for me, the most basic setup I've seen is a pair of mics mounted on a stand connected to a DAT recorder...
Obvious noob, but I'm looking to spend maybe $300-500 for an easy way to make good stereo recordings onto my laptop. No fancy mixing required...
Anyway thanks for your patience, I hope you can give me some ideas and suggestions!
Hmmmm, audition tapes eh? I just fixed one up for a friend.
I use an MXL 990/991, I have used MSH1s on some tracks, :cool: and I use an M-Audio firewire solo interface. Recently, my newer recordings sound better due to extensive EQ and proper reverb, levels, etc. Yup, for the upcoming CD I used the Schoepps that the Cleveland Orchestra owns.;)
Having a good room is where its at. I dont.:mad: Having good skills with eq, reverb, editing, automation, etc comes in handy. I recently did an excerpt where I pushed a loud note back a bit. On my upcoming CD, I played a great solo first take but messed up one note. Auto-tune saved it.:D There is a LOT you can do to an audition tape with todays technology. You can visually look at the Midsummer NIghts dream Scherzo to see if it is even, draw in fades, raise accented notes, on and on.
PM me if you have any questions or wanna do shop talk.:cool:
Hey good job, sounds you've done some really interesting work.
For my purposes though I don't think I should be playing with EQ, reverb, other editing... honest truth is what is required on these audition tapes. :)
Since you have experience with Naiants, can I ask how you set them up to record violin/fiddle?
Hmmm. . . my remark about Naiant must have stepped on msh's toes. I did not know that www.naiant.com is listed as msh's homepage when I did that. Nor did I mean to dis Naiant's mics, but just point out that very big, old and experienced companies suggest cardioid mics for violin. They may be models that have switchable patterns, but, for example AKG specifically says to use a cardioid. See the link I posted above.
Leave that stuff for serious analog hobbyists handy with a soldering iron. . .
Well, that is me. But the op said, originally $300 to $500 (not $100 as msh posted above), which means that if he saves lotsa dough on a Naiant mic, then tape is not so far fetched. And, when I posted that I did not know he had chosen to go all digital and no longer had a serious analog system.
As for what is preposterous, lets try
You don't need to accept my argument, it is demonstrable. I have done so in an old thread here somewhere; Dan Lavry has argued the point quite convincingly. 44.1kHz does work fine. It has better frequency response and dynamic range than your suggestion below.
It is not settled that 44.1KHz/16 bit actually achieves anywhere near the theoretical potential in response and dynamic range. But it does have demonstrable problems with phase shift and inaccurate reproduction of higher frequencies. Further, any argument supporting the use of a 44.1KHz sampling rate, and based on Nyquist's Theorem of Mediocrity (Nyquist-Shannon, actually) is based on the assumption that the range of human hearing is 20Hz to 20KHz. Period. At most. But human hearing does not hit a wall at 20KHz, rather it rolls off. We are perfectly capable of sensing harmonics out to, and possibly beyond 27KHz, as some speaker manufacturers have learned the hard way when changing fabric dome tweeters for aluminum domes which had resonance peaks out at 27KHz. Which, if you believe 44.1KHZ sampling to be adequate, should be beyond anyone's ability to perceive.
This guy, the OP, is a classical musician. My posts are only thoughts and ideas, so are not "preposterous," at least not if you really know the meaning of that word. They are based on the assumption that he has at least highly trained hearing, as do the juries to which he will be sending his CDs. I will admit that final judgements will probably be made in person, from among persons selected at first by gross evaluation from CDs. However, these are not people who routinely record or listen to highly compressed pop or rock music. Rather they probably can reliably tell the difference between a Strad and a Del Gesu in a double-blind AB comparision, from recordings. Some probably could tell the difference between the Dushkin Del Gesu and the Ysaye Del Gesu. Blindfolded.
The only thing that matters is getting invited.:D
There is no honest truth in audition tapes. If I rent a hall, some Schoepps, and an engineer, thats completely different than the guy with a Zoom in a practice room. A concert hall IS a reverb machine, and supplies natural EQ. Renting Severance Hall is unfair.:D Sure, using autotune on an excerpt wont serve any purpose, since you have to play it live ultimately at some point. But reverb and eq simply give you some of the tools that the guy renting the hall has. My 2 cents.;)
As far as the Naints:
my recordings are a bit different in that I do fusion stuff, usually with 30 violins on a track. I close mic 2 feet away and somewhat above. For an audition tape I wouldnt do that, I would back up the mics quite a bit, especially if the room sounded ok. Too close and there is too much surface noise.
While violins matter, it's the violinist that makes the sound, not the violin. :) I don't know about guessing specific violins, but even if David Oistrakh and Jascha Heifetz traded fiddles for a day I'd still be able to guess the violinist blind-folded. Now that I think of it, I think probably the same holds true for recording engineers and their equipment, too!
But come on please don't derail the thread dude. Let's come back home... budget $500, best bang for buck I can get with that.
I'd try a pair of naiants, a TASCAM US122, and Reaper. You'll have money left over for a nice Mother's Day gift.
Ive been on a zillion audition committees. Most symphony players know about as much about audio as LeBron James knows about pinball.:D Half of them dont even own stereos! No, as fars as a tape/CD situation, They wouldnt know apogee from close-n-play.:D
The tape audition is real quick. Its to see if you can hit the notes. They might not listen to more than 15 seconds if it is a bad player. Its not over-analyzed, its "yes" or "no" to see if they invite you to audition. That said, a good recording cant hurt. But I wouldnt go all extreme, it doesnt matter. A nice audio interface, good mic and good room is it. And editing, as in dont have 15 seconds of blank space. It drives commitees nuts and makes a bad impression. I use reverb because my room is so dry.
Quoted for truth. And this even applies to some degree to international violin competitions! Gotta make that first minute sound amazing... :)
Definitely. 95% of that is how you play the fiddle, and what choice of concerto you have if they ask for one. I always do Bartok #2, it has served me well.
For the other 5%, its the recording. In general I notice that people hate "dry". They confuse that with bad tone. Thats why a live room is important, or why I add reverb. Actually, I havent made an audition tape for myself in years, but others have come to me to record theirs. They are always happy with the reverb since my space is so dry.
For the record, I like the AKG mics on violin. I dont own any, my recording focus is primarily synths since I dont have the room.
A good point, so let's focus back on our OP's original problem.
Back to a point I made before this got derailed: I'd begin experimenting with room acoustics via reading up on whatever you can find, on line, and, if you have access/time, in libraries. Then play around in whatever space you have already got experience recording in (living room, etc.) and see what you can do to make the recorded sound better. This should be free or cheap to do, and you will be beginning to learn what effect it has on your recorded sound. Meanwhile, don't rush to buy equipment until you fully research the matter. Easier to avoid a costly mistake that way. Or even an inexpensive mistake.
My mention of the violins was not adequately explained, please let me correct that: It was to underscore the points that cutting off the highest frequencies that can be reproduced at approx. 22KHz is too low, and that classical musicians have highly developed and trained hearing. Their ears almost have to be among the best trained on the planet or they wouldn't be at the top of their profession. Assuming, of course, that we are talking about those at the top. And, our goal is to help the OP get to the top, right? :D Thus, for practice, I was suggesting that he at least sample at the highest rate he can afford, so that all high harmonics from his instrument/technique interplay are reproduced as accurately as he can get. That way he gets the best feedback to perfect his craft. Kind of like saying that I prefer getting dressed by looking in as accurate a mirror as possible, not one that is partly greyed out or dull.
And, of course, the greatest bit-depth he can afford too, the better the dynamic range that way.
Now, a question for eug_fiddler: do you only have the Mac Book to work with? And do you want us to look for the best 1394/firewire interface for that, or do you also have a desktop computer which can take a PCI sound card?
Last, but not at all least, I agree that honesty is the best policy. Your juries are going to be very critical of technique and will probably frown on any attempts to cover anything up. Remember the old joke: Famous violinist (Stern, Heifetz, whoever, take your pick) is wandering around in New York lost. He stops someone and asks them the best way to get to Carnagie Hall. The passerby replies "Practice, practice, practice."
If the room is crappy I would suggest the opposite: cut the high end.:D Violins are noisy buggers. If one is recording in a small room, its going to sound like crap. A concert hall basically cuts the high end off too. The larger the room and higher the ceiling, the less that one has to do eqwise. If its a good room you just press record. If its a bad one you have to work to get a sound.
There is a difference between "bright" and "offensive".:D In a bad room, a recording would hurt to listen to . The truth is that most people have never heard a vioin up close in a small room, they are extremely noisy and very shrill.
Yep, Macbook is all I have. I'm leaning towards a Firewire interface from PreSonus (Firebox or Inspire) seeing that I'll only need 2 channels.
I have a better one for you.
Fritz Kreisler and Sergei Rachmaninoff in concert. Kreisler has a big memory slip, whispers to Rach, "where are we?" Rachmaninoff without dropping a note replies, "Carnegie Hall."
Yep again with more truth... one of the keys to performing on stage is knowing what sounds horrible under the ear, but in the hall loses all of its offensive edge and sounds brilliant.
On the other hand if you make a pleasant sound under your ear in Carnegie Hall you likely won't be heard. :)
:D Love it!
As per the original purpose, will look into the interfaces you mention and render opinion and reasons for opinion. May take until tomorrow.
DavidK, which AKG mics do you like for violin, and, for edification of our OP (and me), why?
My point about cutting off the highs or not was more that he control them with acoustic treatment, but still capture what he is doing accurately, all the way up as high as he can, on the recording. That way he has the best feedback on what he is doing. Or, put another way, he doesn't want them accentuated by the room's acoustics, but he doesn't want to simply fix that by cutting them off on the recording either.
AKG does make a bunch of mikes they recommend for violin that are less expensive than the C414. Haven't looked a prices yet, but some are probably considerably less costly than the 414, and sound darn near as good. Ditto Shure. Have heard that the AKG Perception line is one to avoid, though. An attempt to "leverage" the AKG name with "affordable" Chinese-made mics that are simply not up to the standard of the rest of the AKG line.
eug, where did you study?
I like the c414, because it makes me sound purdy.:D
Agreed. Cutting anything is a last resort. However, as someone who has sat through hundreds of audition tapes, I can verify that some people would have been better off if they had eq'ed. Again, it goes to the UNfairness that some people rent a hall, and some play in their untreated living room.
For what it's worth, I think violinists have the most damaged hearing (esp the left ear) from being EXPOSED to such high frequencies all the time. What makes a great violinist great is not necessarily bat-frequency hearing...
Some people recommend getting musicians earplugs (with flat frequency response) to protect the left ear.
Royal Northern College of Music in Manchester England. I'm right now preparing for grad-school auditions, in particular i'm trying to get into the Hanns Eisler in Berlin...
On the contrary, I was enjoying that fact that you didn't know ;) And I generally don't discuss my products here. Thus, I specifically did not make *any* microphone recommendations, for the simple reason that I don't know, it really depends on the source, the mic, and the desired result. The 414 could be a very good recommendation.
However, I will always take issue with statements of opinion, especially based on limited experience, when they clearly conflict with evidence-based analysis.
So let's move on that front, and ignore the discussion of any particular model of microphone.
I believe that is a total budget, and he followed up with a post asking for a $100 mic. A pair of 414s is close to $2K, I believe.
As for what is preposterous, lets try It is not settled that 44.1KHz/16 bit actually achieves anywhere near the theoretical potential in response and dynamic range.
A modern 16 bit system should attain slightly less than 90dB dynamic range. Nearly any 24 bit system can easily exceed that, up to even 130dB for the really high end stuff.
44.1kHz does not *quite* achieve flat response up to 20kHz. There is a slight rolloff of frequencies above 16kHz, due to filter behavior. This is mostly gone when using 48kHz, and totally gone by 64kHz. Any higher rate adds no audible benefit, and rates above 96kHz actually may *decrease* sample accuracy.
This is because the data rate is based upon a much high true sample rate, usually 3mHz or so. The bit depth at that rate is quite small, 1 or 2 or 4 bits. That is the true sample rate; the data rate is constructed from that stream. Thus, any individual sample at 192kHz is constructed from less information than a sample at 96kHz. Therefore, in going to the higher rate, you lose accuracy in the audible spectrum in exchange for frequency response that you can't hear and your system cannot accurately reproduce.
I discussed frequency response above; the comment about phase shift is incorrect; I can post a link if you need, but you can also verify that experimentally yourself. It is based on a faulty assumption about the function of the antialiasing filter, or perhaps the operation of very early filters that were superseded more than 20 years ago.
Let's stipulate that. You have still not given me an argument to use 192kHz. Yes, I said 44.1kHz was adequate, not perfect. 64kHz would remove such worries, and 96kHz would completely address them.
At the same time, you have posted a very compelling argument, if correct, to use equipment that is capable of accurately reproducing ultrasonic frequencies. Which has more accurate ultrahigh frequency response; a large diaphragm cardioid condenser, or a small-diaphragm pressure omnidirectional microphone?
You are also giving an excellent argument not to use a tape recorder that does not have useful response 18kHz . . . such as a low-speed unit like the Revox.
As for dynamic range, really for solo violin you don't need much. That is good news for the Revox, which can only manage about 66dB with Dolby (wanna talk about what that does to high frequencies?). Figure on room noise at 20dBSPL in a really quiet room (not realistic for a home setting), and max SPL at 3' of 100dBSPl (which I'd guess is way high, but let's be conservative). So there is no need for much more than 80dB of dynamic range. Even the low-end 24 bit converters manage 105dB or so.
Mmm hmm. I see in your later posts you attribute that ability to a musician's ability to hear above 20kHz. You will need to reconcile that with recent studies done in the UK where hearing protection may be mandated for classical musicians, since the SPLs experienced in your work environment are more than sufficient to lead to hearing loss. In fact, I would bet my 8 year old daughter could completely embarrass you in a high-frequency hearing test (as she can with me).
But she cannot describe the sonic characteristics of microphones as well as I can, because as you note she is untrained. And she isn't a very good violin player, even after three years of lessons, so I expect your characterization of instrumental tonal qualities is vastly better. So despite our aged hearing, we are superior at those tasks . . . because we are making evaluations of material that is entirely within the audible range.
