bouldersoundguy
Those are all short cables, and none are balanced. You don't want to run unbalanced more that 7 meters or so.
You're going to need a couple of long balanced cables so you can place the recorder more freely. A pair of mic cables might do it depending on whether the H4n can handle line level into its XLR inputs. If the XLRs can't handle line level then maybe you'll have to use the TRS (balanced 6.35mm) inputs. In that case I would have a pair of 10 or 15 meter XLR-F to TRS cables. Along with those I would consider something like this:
ART Pro Audio
Add a selection of cables like you listed plus a couple of others and you can interface with just about anything.
There's also the other method of putting the recorder at the stage end of things and splitting the mic cable directly into the recorder. That would require an XLR splitter and an extra XLR cable. Other than having to arrange to disconnect the mic cable from the mic and connect the splitter it's simpler than having the mic at the desk end. And you'll probably get more separation between you and the audience which might sound better or give you more control in editing.
ART Pro Audio
