Slouching Raymond
The samples have a nice lo-fi character to them.
Thanks! I was hoping to get that kind of sound from the start. I wasn’t sure if cassette would sound lo-fi enough, but recording each sample onto some old tape seems to do the job for that “Mellotron” vibe — even though, from what I can hear, a real Mellotron has a bit more high-end presence.The samples have a nice lo-fi character to them.
For playing samples use Kontakt - and if you are after a specific tone - like tape wow and flutter and semi decreased frequency response - just build it into your samples.I wish there was a worthwhile free Mellotron VST for Mac, that you could record your own samples to... in fact I was looking for one yesterday, no luck.
Thanks, I've been using DirectWave from FL Studio, I should look into Kontakt. Is it free? Would you prefer this over the one I used? Also before making it in DirectWave, I wanted to make in in DecentSampler I discovered through David Hilowitz YouTube Channel (I warmly recommend its channel), but I still have to figure how to use it.For playing samples use Kontakt - and if you are after a specific tone - like tape wow and flutter and semi decreased frequency response - just build it into your samples.
Kontakt Player is free - But you can’t create or manipulate samples with it - Are you wanting to create Mellotron type sounds? It’s a bit hard to emulate a Mellotron - part of the sound is the mechanics involved - tape playback - worn out tape after a bunch of playback - Limited Frequency Reponse - Tape Wow and Flutter - all sorts of things - when it was first used the Mellotron were mostly in optimal shape and didn’t experience those sort of things - The Beatles Strawberry Fields be a classic example - Brand new tapes and the machine was tweaked out by John Pinder - but if they ever went on the road …..Thanks, I've been using DirectWave from FL Studio, I should look into Kontakt. Is it free? Would you prefer this over the one I used? Also before making it in DirectWave, I wanted to make in in DecentSampler I discovered through David Hilowitz YouTube Channel (I warmly recommend its channel), but I still have to figure how to use it.
Thanks, the whole thread was me documenting my journey creating a DIY mellotron with a cassette recorder. I tried to make a violin today following the same process i did for the flute (a 3Violin preset), but it's quite bad. It probably helps to know how to actually play a violin (playing 3 squeeqy violons in unisson here was quite tedious to do) . Here's a short example of what I've recorded today.Kontakt Player is free - But you can’t create or manipulate samples with it - Are you wanting to create Mellotron type sounds? It’s a bit hard to emulate a Mellotron - part of the sound is the mechanics involved - tape playback - worn out tape after a bunch of playback - Limited Frequency Reponse - Tape Wow and Flutter - all sorts of things - when it was first used the Mellotron were mostly in optimal shape and didn’t experience those sort of things - The Beatles Strawberry Fields be a classic example - Brand new tapes and the machine was tweaked out by John Pinder - but if they ever went on the road …..
Playing the sounds is rather easy - I use the Arturia Mellotron V and my Arturia Keylab Controller - the sound is there and works everytime - everywhere -
Yeah I know it's awful. The flute one didn't end up too bad (altough not great), this one is really terrible. The vibrato was just me adding a LFO on the notes before sending them on the cassette recorder (i can't play a vibrato on the violin, I just own one, I never really played it). My casette deck is fine although very noisy (But I mean, isn't that the charm of it?). For anyone curious, here's the samples as I got them :Nah, that wasn't lofi. That was bloody awful! The sound is just "wobbely". Not like vibrato that a real violinist would make. It's just completely off pitch. If that's function of the pitch stability of your cassette deck, you need to take it in for service!
