I... But now that I think about it, I don't think I ever tried adding a stereo effect to a mono track to see if it mixed the effect stereo... I guess I will try that. I just record my guitar stereo because I'm going through a multi-effects box that has stereo out and actually sends distinct audio to the L/R tracks. All my mics are mono...
But that's still not really ster.........
....oh...nevermind. *sigh*
Here you go hand over the ores I'll row for awhile.
If you use one mic (or one direct connect) for your amp or whatever, you've started mono.
There's no need to record this other than a mono track.
To record
this to a stereo track- you've only told the recorder (DAW) to record the same thing to a pair of connected tracks.
Now, the DAW doesn't know the same info is on both sides (L&R) and that you just used and wasted twice the file size.
But, it also doesn't care whether you picked a mono track or not because-
Once it's in the DAW—ALL of the track paths are DUAL paths.
There's a real good reason for this. Even if it is just a mono' (single file), it has to allow for you to
a) pan it anywhere in the 'stereo' mix and
b).. It also has to allow that you might want to slap a nice 'stereo reverb' onto that mono track.
Now- the distinction. ...We all need this.
Content vs. the paths.
The same thing on both sides is-- Mono.
Period.
..On a 'Stereo Track'?
The difference is the
content is (or can be) mono, but the paths are dual.
You can call the mix, the mixer output, your CD whatever, 'stereo' because of their two sides or cables or it's a file with 'L & R'- But it isn't stereo sound (content) until there is a difference coming out of L & R.
This..
is different
sounds on left and right, therefore record into a 'stereo' track ..Or, a pair of mono tracks. (Ask why. Win a prize.
![Smilie :) :)](/images/smilies/smile.gif)
You want
dual paths for capturing
dual content.
If I used two mono mics and they are position almost identical V shaped, then one goes into the right and the other to the left. This creates stereo, yet its from the same source at almost the same position and this is stereo?
This sounds like you're describing XY stereo mic placement. Two directional mic diaphragms in the same spot but angled gives you time coherent pick up (solid accurate image and phase) with only
level differences from L/R due to the mic's patterns making it stereo sound.
To make it wider (more difference between L/R) increase the angle (more 'side difference, less 'center the same') or, separate the mics some (now you are introducing time and phase differences.
See ORTF- a little bit of (intentional) high frequency phase error (candy..), or 'Spaced Pair- lots of space, less 'accurate' center and image.
Hey man.. These Aussies..
They make some frikin great Shiraz.
![Wink ;) ;)](/images/smilies/wink.gif)
