philbagg
Just Killing Time
Recording with 2/multiple mics has its benefits.
I doesn't just make the signal louder, unless you're using two of the exact same mic in virtually the same place - in which case all you're doing is introducing the possibility of phasing issues, just to make it louder.
Different mics have different frequency responses. Example: You could throw a 57 on one speaker for the presence of the cab, and then a D112 to pick up the low-end detail.
Now, I know you'll end up cutting out most of that super low-end, but it's just an example.
Also, using multiple mics allows you to play with phase. Sometimes phasing is what you want to avoid as we all know, but sometimes playing with the phase of multiple inputs can alter the sound for the better. It's like EQ'ing the sound before it goes to tape.
There's also the example of using one mic about half an inch from the speaker, then one or two dotted around the room to pick up a more ambient tone. The two can really blend together to get a huge sound, especially with good placement in the stereo field.
Then again, there's also just giving yourself options. You might throw 3 or 4 mics on the one source, and then decide to keep one when it comes to mixdown. It mightn't be clear what you want to use when tracking, but it can become more evident later on.
