K
katmandude
i've done some quick recording tests by reocrding my deluxe reverb amp. Should I assume that since I am micing the amp, I should plug the mic into the vocal/mic1 input rather than the guitar imput? I did it this way, both dry, and using the basic compression effect. Seemed OK. not sure which I liked better yet.
Is this right? I want to get the best possible signal. I also think I may need to get an ART tube mic Pre for better signal, and maybe warmer signal too. anyone agree with this or suggest another way?
lastly I assume that if I mic the amp through the vocal input, that I can split the guitar's signal before the amp, and also go direct to the br-8 guitar input. that way I could get 2 tracks of guit, and mix the effect of the real and the fake amps. Does this make sense?
thanks in advance for your help as always. I have found this forum to be extrememly helpful and I appredciate it.
